Progdvb isn't compatible with TechnoTrend TT-Premium S2 twin
coelhomd
coelhomd
Thu May 26, 2011 4:44 pm
#1 by coelhomd
Current version of Progdvb 6.71.1 tested today (both 32 and 64bit) with TechnoTrend TT-Premium S2-6400 Twin HD
Device is detected, but is not able to scan channels. No signal.
I hope you fix this compaptibility.
Thanks.
  • Sun Sep 11, 2011 1:06 am
ramtinradin
ramtinradin
Fri Mar 09, 2012 3:28 pm
Re: Progdvb isn't compatible with TechnoTrend TT-Premium S2
#2 by ramtinradin
dear prog
when supported technotrend s2 6400 ?
  • Fri Mar 09, 2012 4:55 pm
#3 by Prog
I am not have sample. This is quite exotic device...
  • Mon Mar 12, 2012 7:08 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 9:49 am
