    • Unanswered topics
    • Active topics
SS2:Progdvb 6 geht nicht unter WIN7, DVB-Viewer funktioniert
atilla
atilla
Wed Nov 02, 2011 8:13 am
#1 by atilla
Ich habe eine Skystar2 - keine HD-version.
Bei mir kommt beim Versuch mit ProgDVB TV-Sender zu sehen unter WIN7 der Fehler "device not started". Der technisat-eigene DVB-Viewer funktioniert hingegen tatellos.
Was kann ich tun?
  • Wed Nov 02, 2011 8:18 am
Re: SS2:Progdvb 6 geht nicht unter WIN7, DVB-Viewer funktion
Do you use ProgDVB x32? Check Settings->TV Sources.
  • Wed Nov 02, 2011 8:22 am
atilla
atilla
#3 by atilla
No, I use the 64bit version of WIN7.
  • Wed Nov 02, 2011 11:31 am
#4 by Prog
Please try ProgDVB x32 also. DVBViewer x32 application, may be problem in x64 part of driver.
  • Wed Nov 02, 2011 3:22 pm
Return to “German”
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sun Dec 14, 2025 5:12 am
