ProgDVB6.71.1Pr Streaming on the local network peoblem
hammoudx
hammoudx
Mon Nov 07, 2011 2:58 am
#1 by hammoudx
hi all
I am using ProgDVB6.71.1Pr
I tried many modules to steam on the local network but I never get with it
Any Full instructions to do it will be appreciated
Thanks in advance
  • Mon Nov 07, 2011 3:44 am
Re: ProgDVB6.71.1Pr Streaming on the local network peoblem
What type of streaming you like use?
  • Mon Nov 07, 2011 6:21 am
hammoudx
hammoudx
#3 by hammoudx
Prog wrote:What type of streaming you like use?
normal streaming to the client computer on the local lan , to play it on Vlc or any player
  • Mon Nov 07, 2011 12:59 pm
#4 by Prog
IPTV or?
Try last version of ProgDVB + last version of Prog Media Server Pro.
  • Mon Nov 07, 2011 1:31 pm
Return to “Modules”
Вы мне логи крашей присылали?
  • It is currently Sun Jun 28, 2026 1:03 am
