    • Unanswered topics
    • Active topics
Record in WMV
chrisstavrou
chrisstavrou
Mon Aug 01, 2011 5:10 am
Record in WMV
#1 by chrisstavrou
Hi,
i am trying to record in wmv format but no file is created.
Do i have to install any additional encoder ?
If yes how can i get it ?
Thank you
Chris
  • Sat Nov 26, 2011 6:24 am
Re: Record in WMV
Do you try that in old versions?
  • Sat Nov 26, 2011 7:13 am
chrisstavrou
chrisstavrou
Re: Record in WMV
#3 by chrisstavrou
Hi,
i am using 6.73.04 and running under winx xp sp2.
Thanks
  • Sat Nov 26, 2011 3:29 pm
You can try prerelase of ProgDVB.
Prog, Mon Dec 15, 2025 4:53 pm
I am not download this list. Really huge list. I change your password in list and use it as crash test:) ProgDVB very sl
Prog, Mon Dec 15, 2025 7:39 am
А лучше ссылку на канал. mkv/mp4 неудобные форматы для записи и всегда будут отличаться тем, что работать хуже чем TS. П
Prog, Mon Dec 15, 2025 7:10 am
running raseberry tv on progd…
i have it running on 2 other windows devices with no problems . i bought a new subscription for a third device and it!s
prop, Sun Dec 14, 2025 11:59 pm
  • It is currently Mon Dec 15, 2025 6:40 pm
