I am installing ProgDVB 4.80.1 on XP P4 PC with TwinHan StarBox.
OEM TwinHan software is working fine.
The LNB has been configured and generates a "Not Defined" Listing of channels on the left of screen.
I get the above error during installation of ProgDVB if I click on one of the green channels.
XP Firewall has been set to allow ProgDVB access.
I'll go along with operator error, but any suggestions?
thanks
Dave.
Set timeshiftbuffer to operate in RAM : Settings->audio/video->TimeshiftbufferError of create file of buffer
Yep, operator error.
I did as you suggested and all came good.
I then created the directory I chose to use for time shift and all is well there too. Very slick program. See how much more trouble I can get into...
Thanks
Dave
