    • Unanswered topics
    • Active topics
no plugin menu
salvia
salvia
Sat Dec 17, 2011 1:27 pm
no plugin menu
#1 by salvia
hi all, can anyone tell me why i can not see the plugin drop down menu.
please have a look at the screenshot.
regards, salvia
  • Sat Dec 17, 2011 1:32 pm
Re: no plugin menu
http://www.progdvb.com/manual_faq.html point 1?
  • Sun Dec 18, 2011 7:44 am
salvia
salvia
Re: no plugin menu
#3 by salvia
No, atm i have the 32bit version installed. but before i had used the 64 bit version. in this version the plugin menu was visible.
regards, salvia
  • Sun Dec 18, 2011 12:31 pm
Re: no plugin menu
#4 by Prog
Other reason if you not select no one device in TV Sources dialog. In this case better install last version of ProgDVB.
  • Mon Dec 19, 2011 2:58 pm
javimelon
javimelon
Wed Jan 25, 2012 12:16 pm
Re: no plugin menu
#5 by javimelon
Prog wrote:Other reason if you not select no one device in TV Sources dialog. In this case better install last version of ProgDVB.
Yes, it´s the solution.
  • Wed Jan 25, 2012 1:44 pm
Re: no plugin menu
#6 by Prog
What link?
  • Mon Jun 25, 2018 11:44 am
Return to “Modules”
  • It is currently Sun Jun 15, 2025 1:28 am
