How to install St@rkey usb box to Windows 7 home (64-bit)?
sroinine
sroinine
Tue Jan 03, 2012 7:36 am
#1 by sroinine
Hi all,
I have St@rkey USB box. I have tried to find installation guidelines/driver software for Windows 7 home (64-bit) without success. It seems that ProgDVB supports that old box still. May I ask installation guidelines?
Many thanks,
Seppo
  • Tue Jan 03, 2012 7:42 am
Re: How to install St@rkey usb box to Windows 7 home (64-bit
This is very old device and I think no any driver for x64.
  • Wed Jan 04, 2012 1:14 pm
jack kallis
jack kallis
Fri Mar 30, 2012 12:22 pm
#3 by jack kallis
You can download installation guide from the internet,read the instruction and follow the guideline.I am sure it will definitely work.
Antivirus Support
windows support
  • Fri Mar 30, 2012 12:28 pm
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 9:48 am
