Error with Sheduler
Hi,
since the new progdvb-engine i've problems with the sheduler.
i set the turn computer off command, go to bed, wake up in the morning before my alarm beeps cuz some tv-ad was to loud :D
so what can i do?
actually i use progdvb 6.80.03 x86 professional (baught at v4).
Re: Error with Sheduler
Hi All,
It will run sometimes then it fails. Most of the time it will run after I have processed the cube manually. Then when I re-run the job from the failing step it will go through.
I get this error from the cube when I schedule it:
Executed as user: SERVER\SYSTEM. ...9.00.5000.00 for 32-bit Copyright (C) Microsoft Corp 1984-2005. All rights reserved. Started: 10:41:04 AM Error: 2011-10-10 10:42:17.24 Code: 0xC1000007 Source: SSAS Cube rebuild Analysis Services Execute DDL Task Description: Internal error: The operation terminated unsuccessfully. End Error Error: 2011-10-10 10:42:17.24 Code: 0xC11F0006 Source: SSAS Cube rebuild Analysis Services Execute DDL Task Description: Errors in the OLAP storage engine: The process operation ended because the number of errors encountered during processing reached the defined limit of allowable errors for the operation. End Error Error: 2011-10-10 10:42:17.24 Code: 0xC11F000E Source: SSAS Cube rebuild Analysis Services Execute DDL Task Description: Errors in the OLAP storage engine: An error occurred while processing the 'CUBE' partition of the 'CUBE' measure... The package execution fa... The step failed.
