Change in Channel Properties?!
Hi Prog,
How to change in Group by from "Country, Genre, None" to "Satellite, Frequency" in Channel List Properties?What should I do to change these settings?
Why have you changed these settings in recent versions?It is more important to configure the frequencies and satellites and is less important country and gender,at least for me!
regards
Re: Change in Channel Properties?!
Hi ProgDVB,
Please tell me how to change settings for the satellite and not for Internet TV ?I found no way to return player to default settings for satellites,frequencies and not,as it is now, for Country,Genre at Dynamic List Settings!!!{see above my screenshot}
I hope you understand me this time.
Regards
Same Problem here: DVB-C/DVB-T Card ...
I NEED TO GROUP BY TRANSPONDER!!!
DVB-C/DVB-T only allows grouping by "Country" and "Genre", AND NOT BY "Satellite Name", "Network Name", "Provider Name", "Transponder", ETC.
WHY IS DVB-C/DVB-T CARD NOT GROUPABLE BY TRANSPONDER???
And WHY is IPTV and InternetTV NOT deselectable in TV-sources??? I have here Computers WITHOUT INTERNET-CONNECTION! They only have DVB-T Card and CAN NOT use IPTV or InternetTV! HOW TO DISABLE in TV-Sources???
And how to create my on list with my own way of grouping and my own way of sorting inside the groups?
The flaw was introduced with Version 6.80.2 ... downgrading to Version 6.80.1 or below "solves" the problem temporarily.
So you always have to downgrade to 6.80.1 or below, group again by transponder, satellite etc. - and then reinstall the latest version ...
That might be a workaround - but that's no solution!
Please see bug thread here.
There are two ways of grouping channels: either by popup-menu inside channel list properties window (that's what all those try to do and wonder that the only grouping is "by country" and "by genre" - what both groups by network) - or by right-clicking in the channel list itself and chosing the submenu in the big options menu: there it is possible to group by transponder, satellite, network etc. But be careful: if you try to group an internet-channel-list by transponder (what is possible there, but does not make sense), the application will crash.
