    • Unanswered topics
    • Active topics
problem in progdvb 64bit with windows 7 64bit with wdm drive
firefoxsweet
firefoxsweet
Wed Dec 13, 2006 12:35 pm
#1 by firefoxsweet
Hello
I have skystar2 ,i have installed wdw driver in windows 7 64bit
- with progdvb 32 bit it work correctly
- with progdvb 64 bit it doesn't work "[Sky Star 2 (WDM)] Device not started! "
which the best wdw driver or bda driver
  • Fri Feb 03, 2012 7:38 pm
Re: problem in progdvb 64bit with windows 7 64bit with wdm d
BDA is more simple for x64. For WDM you should found and install Sky2PCAVSrc.ax
  • Sat Feb 04, 2012 12:40 pm
  • It is currently Wed Jun 18, 2025 10:42 pm
