    • Unanswered topics
    • Active topics
Skystar 2 pci + DiSEqC 1,0 + LAV filters
e1iminator
e1iminator
Sun Feb 05, 2012 1:31 pm
#1 by e1iminator
hi,
it just doesn't work. i can't switch channels between satellites. i have to restart the application or change renderer to switch. can you make progdvb use LAV splitter/demuxer directly?
thanks
i use an nvidia card
  • Sun Feb 05, 2012 1:38 pm
Re: Skystar 2 pci + DiSEqC 1,0 + LAV filters
ProgDVB not support LAV splitter/demuxer (I am not sure about Push demux in this filters pack). But what problem with Prog Demux?
  • Sun Feb 05, 2012 2:21 pm
e1iminator
e1iminator
#3 by e1iminator
the same. i cannot change channels between satellites
  • Sun Feb 05, 2012 2:32 pm
#4 by Prog
Settings for diseq in Settings->Options. It is not depended from demux and filters.
ps: Also you can try change driver to BDA or to WDM
  • Sun Feb 05, 2012 3:11 pm
e1iminator
e1iminator
#5 by e1iminator
i use WDM BDA doesn't work at all. when i change renderer like from EVR to renderless channel displays. i change again to other satellite channel. no channel displays
  • Sun Feb 05, 2012 3:30 pm
  • It is currently Sat Jun 21, 2025 1:35 am
