TBS 5922 USB
I've tested TBS 5922 USB with progdvb 6.8.x, Diseqc 1.0 does not work. It goes only to first diseqc port 1. Any idea why. It does work with the supplied TBS software and other DVB soft. Thank you
Win7 RAM =4GB ,INTEL Core 2 Quad Q6600 2.4Ghz , GIGABYTE GA-EP45-DS3R, Technisat Skystar 2 PCI driver 4.6.0, Diseqc 1.0 4 ports
Re: TBS 5922 USB
How to select this tbs.eba2? I see it is listed in the module subdirectory.Please explain.
Re: TBS 5922 USB
ok it just doesn't work. I must switch diseqc with another program ( say TBSviewer ) first to get progdvb work. so it will work only on that particular port.The problem is with Diseqc switching. Whatever i do progdvb won't switch my diseqc.
Re: TBS 5922 USB
Today i did further tests
1. I copied folders from a previous installation( Progdvb Ver 6.06) and copied it in My Documents folder.copy tbs.ebda to module folder. Diseqc worked fine.
2. I copied same folders above to C;/ program files /overwriting existing progdvb installation. Diseqc still worked.
3. I downloaded latest progdvb ver 683.03 and update. Now asking me to input Diseqc. Go to advance options. Choose Switch then add LNB one by one
Now Diseqc failed......
What have I done wrong ?
