    • Unanswered topics
    • Active topics
Prog Finder, only moving in steps?
Likvid
Likvid
Fri Mar 30, 2012 6:39 pm
#1 by Likvid
I really like Prog Finder but i can only move the motor in steps, it takes very long time to manually move.
Is it possible to hold East or West button and it contiunes moving the motor and then stops when you release the button?
  • Sat Mar 31, 2012 12:14 am
marec
marec
Wed Jun 24, 2009 3:27 pm
Brazil
Re: Prog Finder, only moving in steps?
#2 by marec
There are many issues with Diseqc 1.2 panel of Progdvb. Prog says its all ok, and if they exist, they are "in your hardware" and dont fix problems. :(
As a sugestion, I would ask for a "ten steps" button options. That would cut moving time enough, and still let see the level of the signal.
  • Mon Apr 02, 2012 11:50 am
doug4knfpu
doug4knfpu
Fri Jul 20, 2012 7:49 pm
#3 by doug4knfpu
have there been any updates to fix the problem or a easier way?
Clermont Downtown Partnership
  • Mon Jul 23, 2012 7:11 pm
#4 by Prog
Try set step number in "sat position" field.
  • Tue Jul 24, 2012 5:51 am
Return to “Modules”
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sat Dec 13, 2025 11:00 pm
