    • Unanswered topics
    • Active topics
what are the limits for the timeshift buffer?
midori
midori
Sat Nov 29, 2008 12:18 pm
London
#1 by midori
i have 8 GB ram, win x64 and i'm using the 32 bit version - what is the max possible value for the time shift buffer? each 32 bit process should be able to use 2 GB but i can not assign more then 1200 MB, as i get an error message. why?
  • Tue Apr 24, 2012 5:06 pm
Re: what are the limits for the timeshift buffer?
Limit of OS. Because impossible take more 700mb by one piece. Use x64 version for use unlimited size.
  • Tue Apr 24, 2012 5:21 pm
midori
midori
London
#3 by midori
Prog wrote:Limit of OS. Because impossible take more 700mb by one piece. Use x64 version for use unlimited size.
i see. i was afraid you gonna say this, hoped thenre cam be a bit more alocated :) x64 would be nice but i need the ACamd plugin as i have a cardreader (phoenix) with a conax card.
  • Fri Apr 27, 2012 8:53 pm
midori
midori
London
#4 by midori
so just for the record:
solution is: use a ram disk and set progdvb to keep the time shift data in a file on a ram disk. works perfect :)
  • Thu May 03, 2012 4:28 am
Re: ProgTV WinUI3
У меня было такие несколько раз. Какие то ошибки/утечки накапливаются как бы в фреймфорке. Пока нет идей.
Prog, Fri Oct 17, 2025 10:02 am
Re: ProgTV WinUI3
kostan: А после перезапуска глюк пропадает? Да.
kostan, Fri Oct 17, 2025 8:11 am
Re: ProgTV WinUI3
Prog, Fri Oct 17, 2025 7:55 am
Re: ProgTV WinUI3
alian: Кстати режим просмотра через libvlc тоже можно попробовать. А так не идей. На рендере по умолчанию, ProgTV не упр
Prog, Fri Oct 17, 2025 7:44 am
  • It is currently Thu Oct 23, 2025 3:06 pm
