Minimal SR limiting command line tool
Hello,
Since i have a problem with the minimal SR my card can handle, i've written a command tool to fix the satellite ini file for a minimal SR.
Usage: SatListFix <inputfile> <outputfile> <minimum_sr>
e.g. SatListFix 3592.ini new.ini 6000
The program will eliminate all transponders below the specified SR and write out a new ini file with proper numbering according to the remaining transponders.
If the input and output file is the the same, the input file will be correctly overwritten.
This allows e.g. the batch processing of all ini files:
for %%i in (*.ini) do SatListFix %%i %%i 6000
Have fun.
DocMarius
ProgDVB Pro, registered, of course.
SatListFix-1.0.zip
Transponder list minimal SR adjust command line tool
(22.2 KiB) Downloaded 938 times
