Still there are many bugs to fix, to get a stable version.
Hope Prog keep not releasing versions without minimal tests, as it was happening, I guess.
No need for so many versions, if they have bad performance.
Opened this topic to everybody ask and suggest for fix to the 6.84 series.
To begin, some audio issues, hope Prog do some tests.
1- The audio processor is very problematic this series. Cant use it at all.
2- The Prog audio renderer is problematic too. I remember it has low volume, and is unstable.
Think asking to fix this is enough for a new version
