No signale graph on my QQ box :(
quick
quick
Fri Jun 22, 2012 10:52 pm
#1 by quick
hi i have QQ BOX card works with all dvb viewers but progdvb the one i use all the time dosnt show signale with this card QQ BOX
driver> (DVBS_SHARP7395_20090317_x86_x64)
so please if you can fix it that well be nice thank you progdvb
  • Fri Jun 22, 2012 11:04 pm
Re: No signale graph on my QQ box :(
Try change Settings->Device options-> Use tuner space.
  • Sat Jun 23, 2012 4:23 pm
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 9:48 am
