I don't know in which version it came up after 6.81.x, but now in 6.86.4 I have an unwanted snapshot sound when taking a picture from TV. Can I somehow disable this? If not, is there a trick, that it simply does not fire? Config file? Rename a file? ... I just don't want it to make any sound...
Regards;
Shaker
Re: Can I turn off snapshot sound?
#3So, currently it's "hard coded"? No parameter? No soundfile to rename / delete?
Are there plans to make the sound optional in one of the next releases?
#4Too much remarks about ProgDVB sound. May be make mechanism to adjust the sound level and the folder for users own samples? In the future sounds can be more. And wasapi....
#5wasapi is total block all sound steams in system. like in windows 3.11
#6i knew it. but no hopeless situationsProg wrote:wasapi is total block all sound steams in system. like in windows 3.11
