Tevii S660 power off?
Matixo
Matixo
Fri Aug 31, 2012 9:25 am
#1 by Matixo
Hi
I'm sharing a motorized LNB between PC and Ariva TS100 receiver. How could I stop powering LNB from my PC?
I'm using Tevii S660 with DVBviewer Pro
Thanks.
  • Fri Aug 31, 2012 9:26 am
Re: Tevii S660 power off?
In lnb properties in Settings->TV Sources?
  • Fri Aug 31, 2012 9:30 am
Matixo
Matixo
#3 by Matixo
Prog wrote:In lnb properties in Settings->TV Sources?
In dvbviewer ?
  • Fri Aug 31, 2012 10:03 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 9:47 am
