    • Unanswered topics
    • Active topics
does DVBEPG work with progdvb?
greenie-monster
greenie-monster
Wed Jan 17, 2007 7:28 pm
#1 by greenie-monster
I just switched from mytheatre to ProgDVB, I am used to DVBEPG for an program guide. I cant get it to work with ProgDVB. Does it work with ProgDVB, or which EPG pluggin do you recommend?
  • Sun Feb 04, 2007 6:55 am
SiLencer
SiLencer
Fri Nov 03, 2006 12:10 pm
#2 by SiLencer
Use Relict EPG ...works like a Charm with Progdvb....
viewtopic.php?t=148
  • Sun Feb 04, 2007 6:56 am
add progdvb pro on another la…
i have prog pro . how can i add it on another laptop? i have already downloaded it but it is on the trail version.
prop, Sun Dec 14, 2025 3:39 pm
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
  • It is currently Sun Dec 14, 2025 5:24 pm
