by Juergen
As you're using a Nexus 2.3, try another (DiSEqC 1.2 compatible) software for it and compare.
And / or test with a suitable receiver, if any possible.
(Modern versions of) ProgDVB should be able to use DiSEqC 1.2 on your card without any plugin. Look into the device list, mark the SS1, read features support list.
No idea, how positions are stored in / for your motor.
Get hold of all documentation you can get for it and read.
Only an owner of such a hardware config like yours would perhaps be able, to write some manual for it. I don't move my dishes, use multifeed instead. AFAIK Prog and SiLencer also don't use motors.
