    • Unanswered topics
    • Active topics
ProgDVB can't play back own recordings?
r10k
r10k
Mon Sep 24, 2012 5:53 am
#1 by r10k
Am I missing something, or is ProgDVB unable to play back its own recordings? When I click on a recoding I get a short bit of sound, and then nothing.
  • Mon Sep 24, 2012 5:59 am
Re: ProgDVB can't play back own recordings?
What size of record? Can you upload this sample to me?
  • Tue Sep 25, 2012 11:35 am
r10k
r10k
#3 by r10k
I've tried both long (30mins) and short recordings (like this sample) and I get the same thing. If it helps, I'm running the latest ProgDVB Pro (64bit), which was upgraded from ProgDVB free. I'm on Win7.
Here's the link to the footage.
  • Tue Sep 25, 2012 1:11 pm
Установил мобильную ПрогТВ, удалил из папки два шрифта, скопировал свой файл шрифта - не работает. Шрифт в программе обы
kostan, Sat Nov 08, 2025 10:06 pm
If this is what you mean, yes i can send you the file, just tell me how, Thanks. I've sent the logs to the de
nikspk, Sat Nov 08, 2025 7:38 pm
Can you send me logs from "bad" and "good" version from same channel? You can install old version from msi and new
AndresMaxx, Sat Nov 08, 2025 5:48 pm
Can you send me logs from "bad" and "good" version from same channel? You can install old version from msi and new a
nikspk, Sat Nov 08, 2025 4:59 pm
  • It is currently Sun Nov 09, 2025 4:36 am
