ProgDVB 6.87.6 64bit crashes on registration
Terijan
Terijan
Mon Dec 05, 2011 3:43 pm
#1 by Terijan
I did upgrade to Win 8 Pro, my HID changed too. If I try to update my registration code on website
http://reg2.progdvb.com/
It says HID is blocked.
If I try to register Prog DVB 6.87.6 64bit online - it crashes.
Any ideas ?
*I use ProgDVB for IPTV only.
  • Mon Oct 29, 2012 11:09 am
Re: ProgDVB 6.87.6 64bit crashes on registration
You can try x32 version also.
  • Mon Oct 29, 2012 6:56 pm
Terijan
Terijan
#3 by Terijan
No. I must register 64 bit version.
  • Mon Oct 29, 2012 8:31 pm
#4 by Prog
Looks like bug in protection in ProgDVB x64+ win8/64. Please wait some days for fix that. You can use x32 with same license.
  • Wed Oct 31, 2012 7:52 am
sami789
sami789
Sun Oct 05, 2014 5:01 am
#5 by sami789
You can easily check out our high quality my braindumps which prepares you well for the real ISM. You can also get success in real University of Colorado at Boulder exam with the quality wikipedia and selftestengine.
  • Sun Oct 05, 2014 10:33 am
Return to “IPTV”
Re: Вывод звука wasapi и asio
  • It is currently Fri Sep 18, 2026 10:18 am
