can't find any channels - Avermedia h339 Lenovo y580
knxv1
knxv1
Tue Jan 08, 2013 1:54 pm
#1 by knxv1
cheers,
just got my new lenovo Notebook (y580). It has an internal TV Card (Avermedia h339). I installed all the drivers properly and ProgDVB lists the card like this:
http://i.imagebanana.com/img/2tk16c7m/yy.png
Unfortunately i cannot find any channels. All searches found nothing. I tryed it with many steps but nothing.
I use the antenna which was included!
Regards!
  • Tue Jan 08, 2013 2:04 pm
Re: can't find any channels - Avermedia h339 Lenovo y580
Try manual scanner also. Do you have signal level?
  • Tue Jan 08, 2013 2:58 pm
knxv1
knxv1
#3 by knxv1
When i use manual seach it shows this:
http://i.imagebanana.com/img/d0k5thk3/zz.png
The Level keeps jumping between 12 and 16, and goes up to about 80 sometimes but just for 1 second.
  • Tue Jan 08, 2013 3:21 pm
#4 by Prog
May be signal really not good?
  • Tue Jan 08, 2013 3:47 pm
knxv1
knxv1
#5 by knxv1
Well as you can see on the second screenshot, it says:
Signal: None.
But why? I plugged the antenna in. And I also tried using the connection which comes directly out of my wall. It looks like this:
http://bilder.hifi-forum.de/max/658443/ ... _52329.jpg
Just no results :(
  • Wed Jan 09, 2013 6:16 pm
#6 by Prog
I am not know. Do you have same problem in original software?
  • Thu Jan 10, 2013 6:23 am
knxv1
knxv1
#7 by knxv1
what original software do you mean?
  • Sun Jan 13, 2013 9:36 pm
#8 by Prog
from DVD from this device.
  • Mon Jan 14, 2013 3:43 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 9:47 am
