    • Unanswered topics
    • Active topics
Pid recorder problem
  • 1
  • 2
dog-man
dog-man
Sat Jan 19, 2013 1:40 pm
#1 by dog-man
I hope someone could help with a problem I have.
If I record a .ts file using the pid recorder facility within progdvb, it does not record the scrambled .ts packets.
Is there a known reason for this?
dog-man
  • Sat Jan 19, 2013 1:50 pm
dog-man
dog-man
Re: Pid recorder problem
#2 by dog-man
I should have mentioned that the stream I want to record is a Biss encrypted stream.
dog-man
  • Sat Jan 19, 2013 1:55 pm
#3 by Prog
It is problem if modern architecture of ProgDVB. I think current realization request less CPU and not have idea why need crypted traffic.
  • Sat Jan 19, 2013 2:14 pm
dog-man
dog-man
#4 by dog-man
Is there a version that will record the scrambled packets?
I run windows 7 64 bit but am happy to run 32 bit.
dog-man
  • Sat Jan 19, 2013 2:37 pm
#5 by Prog
6.6x ?
  • Sat Jan 19, 2013 2:44 pm
dog-man
dog-man
#6 by dog-man
I will give it a try.
dog-man
  • Sat Jan 19, 2013 2:55 pm
dog-man
dog-man
#7 by dog-man
Works fine!
Thanks....
dog-man
  • Sat Feb 09, 2013 12:44 pm
dog-man
dog-man
#8 by dog-man
Do none of the progdvb versions above 6.6 record scrambled pids?
I would like to use a newer version but I do not want to lose this facility!
dog-man
  • Mon Feb 25, 2013 3:59 pm
#9 by Prog
May be in future. But why you need this function?
  • Mon Feb 25, 2013 4:04 pm
dog-man
dog-man
#10 by dog-man
I scan the encrypted pids on Biss encrypted channels (Feeds) and have a chance to find a working key.
dog-man
  • Mon Feb 25, 2013 4:22 pm
serkanguzel
serkanguzel
Sat Nov 30, 2013 8:09 am
#11 by serkanguzel
Prog wrote:May be in future. But why you need this function?
Hi,
When this feature will be given for the new and latest versions?
Regards.
  • Fri Dec 13, 2013 11:16 am
serkanguzel
serkanguzel
#12 by serkanguzel
Hi,
Regards.
Dear @ prog,
Did you work on this issue will be? ( for new versions )
Regards.
  • Sat Dec 21, 2013 9:43 am
#13 by Prog
Still not completed. Problem not in module. Problem in ProgDVB Engine architecture. I am not like degrade optimization for this one case.
  • Sat Dec 21, 2013 12:42 pm
serkanguzel
serkanguzel
#14 by serkanguzel
Prog wrote:Still not completed. Problem not in module. Problem in ProgDVB Engine architecture. I am not like degrade optimization for this one case.
Hi @Prog,
This is about a new development / work do you have?
Regards.
  • Mon Jul 14, 2014 8:47 am
#15 by Prog
Must working in modern versions.
  • Mon Jul 14, 2014 9:05 am
  • 1
  • 2
  • It is currently Fri Jun 20, 2025 7:13 am
