skystar usb hd wont start on prog 32 on windows 64
max92
max92
Wed Jan 30, 2013 9:39 pm
#1 by max92
i cant get my skystar usb hd to start on my windows 8 64 using progdvb 32
it says bda cant start
but it works on progdvb 64 only but no use for it because i cant get the plugins to work on the progdvb 64
any solutions ?
  • Wed Jan 30, 2013 9:42 pm
Re: skystar usb hd wont start on prog 32 on windows 64
May some software use driver in same time?
  • Thu Jan 31, 2013 3:28 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 9:46 am
