Tuner Card
shankarag
shankarag
Thu Feb 21, 2013 10:20 am
Tuner Card
#1 by shankarag
I have installed prolink playtv pro 4 card. will it work with progdvb?
Shankarag
  • Thu Feb 21, 2013 10:24 am
Re: Tuner Card
I am not recommend use ProgDVB for analog devices.
  • Thu Feb 21, 2013 12:57 pm
driverellis
driverellis
Tue Nov 19, 2013 10:37 am
Re: Tuner Card
#3 by driverellis
I have no idea about this,but i get information about your question.
Delightful Cupcake Recipes
  • Tue Nov 19, 2013 10:39 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 11:41 am
