Skystar hd2 problem with no signal at all
Sasa064
Sasa064
Mon Apr 01, 2013 7:46 am
#1 by Sasa064
I have skystar hd2 and all drivers and progdvb 6.92 professional but no signal and can't setup antenna.
I tested my equipment with my friend on his positioned dish with my lnb and mu computer and it works but no signal showing!!!
Any help?
  • Mon Apr 01, 2013 7:49 am
Re: Skystar hd2 problem with no signal at all
x32? Send screen of TV Sources dialog.
  • Mon Apr 01, 2013 10:10 am
Sasa064
Sasa064
#3 by Sasa064
i tried with win 7 x64 and xp x86, pictures i will send later
  • Mon Apr 01, 2013 2:53 pm
Sasa064
Sasa064
#4 by Sasa064
I found the solution! :)
  • Mon Apr 01, 2013 7:07 pm
#5 by Prog
What solution?
  • Tue Apr 02, 2013 5:05 am
dua
dua
Tue Nov 05, 2013 7:55 am
#6 by dua
am using the newest ProgDVB x64 on my Windows 8 Pro 64 Bit with a Pinnacle Pro Sat USB 450e.
My Satellite is set to Astra 19,2° to receive German Channels.
https://www.google.com.pk/?gws_rd=ssl
http://en.wikipedia.org/wiki/Google
http://certkiller.com/
http://www.amazon.com/Google-Amazon-Bey ... 1590591313
https://www.facebook.com/CompTIA
  • Tue Nov 05, 2013 8:01 am
Jovanwillie
Jovanwillie
Sat Sep 13, 2014 7:46 am
#7 by Jovanwillie
Sasa064 wrote:I found the solution! :)
What is solution,Please share with images.
  • Mon Sep 15, 2014 9:10 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 2:34 pm
