    • Unanswered topics
    • Active topics
Channel properties empty for Internet radio
JohnyQ
JohnyQ
Thu May 09, 2013 11:18 pm
#1 by JohnyQ
For some internet radios I get the error "Invalid URL".
So I look at the channel properties and find that the Site field is empty.
Is that normal?
Also:
When I paste a perfectly valid address into this field (http://www.inforadio.de/live.m3u - you can try this URL using VLC and you will see that it is valid.) and try to listen to the radio I still get an invalid URL error.
Can you help?
  • Fri May 10, 2013 11:18 am
Re: Channel properties empty for Internet radio
I am working on my parser for itv. Please wait one of next versions for this that.
  • Fri May 10, 2013 11:46 am
Return to “Internet TV and Radio”
  • It is currently Sat Jun 14, 2025 2:43 pm
