    • Unanswered topics
    • Active topics
Issue with remote control...
r10k
r10k
Mon Sep 24, 2012 5:53 am
#1 by r10k
Hi guys, I have an Avermedia remote control (for use with a dual tuner card). It works perfectly with Avermedia's software, but with ProgDVB I can't get it to do much.
Is there are an easy way to get it working with Prog?
  • Tue May 28, 2013 4:48 am
Re: Issue with remote control...
What type of RC?
  • Tue May 28, 2013 5:33 am
r10k
r10k
#3 by r10k
I'm not sure. It's an Avermedia one that came with the TV card. Is there a way to tell beyond that?
  • Wed May 29, 2013 6:19 am
#4 by Prog
Is it working like keyboard or some specific API?
  • Thu May 30, 2013 4:45 am
r10k
r10k
#5 by r10k
When not being used with Avermedia's TV software most buttons seem to work as a mouse click. I have no idea about an API.
  • Fri May 31, 2013 4:55 am
r10k
r10k
#6 by r10k
Actually, it's an Avermedia RM-KV.
Are these codes helpful?
http://lirc.sourceforge.net/remotes/avermedia/RM-KV
  • Fri May 31, 2013 5:32 am
#7 by Prog
Is it winlirc interface? Try select and setup Settings->Options->Controls->RC=WinLirc
  • Fri May 31, 2013 5:34 am
r10k
r10k
#8 by r10k
Not that I know of... but those codes are for Lirc, so...
I should say, when I try and 'Learn' the remote, nothing happens.
Do I need WinLirc installed?
  • Fri May 31, 2013 5:41 am
In logs total same mode... btw, do you have color changes in ProgTV interface? You can select black color scheme on both
Prog, Sun Nov 09, 2025 6:53 am
Свой файл с тем же именем что и старые?
Prog, Sun Nov 09, 2025 6:51 am
Установил мобильную ПрогТВ, удалил из папки два шрифта, скопировал свой файл шрифта - не работает. Шрифт в программе обы
kostan, Sat Nov 08, 2025 10:06 pm
If this is what you mean, yes i can send you the file, just tell me how, Thanks. I've sent the logs to the de
nikspk, Sat Nov 08, 2025 7:38 pm
  • It is currently Sun Nov 09, 2025 6:59 am
