    • Unanswered topics
    • Active topics
don't have ProgMediaClient device
sa3ad
sa3ad
Tue Sep 18, 2012 8:19 am
#1 by sa3ad
don't have ProgMediaClient device in module list in any pc i installed progdvb on
Uploaded with ImageShack.us
i did register filter
  • Sat Jun 08, 2013 9:39 pm
sa3ad
sa3ad
Re: don't have ProgMediaClient device
#2 by sa3ad
issue solved in the new version 6.94
  • Sun Jun 16, 2013 10:44 am
ArabiaAvonlea
ArabiaAvonlea
Mon Oct 21, 2013 10:26 am
#3 by ArabiaAvonlea
As is well known, Windows operating system consists of a huge number of files and folders. ProgMediaClient.Device is an ordinary process used by the system to launch and run it. If the program stop to response, that means the process are missing or invalid from the applications folder.
  • Mon Oct 21, 2013 10:44 am
Return to “Modules”
You can try prerelase of ProgDVB.
Prog, Mon Dec 15, 2025 4:53 pm
I am not download this list. Really huge list. I change your password in list and use it as crash test:) ProgDVB very sl
Prog, Mon Dec 15, 2025 7:39 am
А лучше ссылку на канал. mkv/mp4 неудобные форматы для записи и всегда будут отличаться тем, что работать хуже чем TS. П
Prog, Mon Dec 15, 2025 7:10 am
running raseberry tv on progd…
i have it running on 2 other windows devices with no problems . i bought a new subscription for a third device and it!s
prop, Sun Dec 14, 2025 11:59 pm
  • It is currently Mon Dec 15, 2025 6:50 pm
