Sky 3D and Nvidia 3dtv play problem
I have a Benq W7000 DLP projector (with DLP link glasses) working very fine with Blu Ray at 1080p/24 hz (Total Media Theatre 6) and with mkv files at the same resolution and refresh rate (Stereoscopic player). My computer is using Nvidia 3dtv play configured for DLP link (not using the nvidia glasses).
The problem is that ProgDVB, when I try to play Sky Italy 3D channel will switch always to 1080p/60 hz instead of using 1080i/50 hz or other combinations supported by Benq w7000 for 3d.
At last ProgDVB will crash and there is no way of changing the resolution or refresh rate manually.
Note: If I record the Sky 3D channel and after I play the .ts file with stereoscopic player I have an automatic switch to 24 hz and apparently the recording is working fine.
