Skystar USB plus remote
1 post
gbdk
gbdk
Wed Feb 21, 2007 4:26 pm
#1 by gbdk
Hi
I have got a Skystar USB plus box, in the box there are a IR reciever and there is a remote included.
But i can´t get it to work with ProgDVB, i have read about Winlirc, but i don´t think that´s with this type of IR.
Any body had luck with this ?
Regards
GBDK
  • Wed Feb 21, 2007 4:32 pm
1 post
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 3:34 pm
