problem with new driver tevii S660
rezakhatarnak
rezakhatarnak
Tue Nov 19, 2013 9:14 am
#1 by rezakhatarnak
when i install the new driver of tevii S660 the DVB shows signal even if i disconnect the LNB wire.
  • Tue Nov 19, 2013 10:01 am
Re: problem with new driver tevii S660
It is normal. Some devices do that.
ps: ProgDVB only show levels from driver.
  • Wed Nov 20, 2013 7:52 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 9:49 am
