I registered many months ago, but have since reformatted my hard drive.
I have re-installed progdvb and when I enter the key, it recognises me and tells me that the program is registered to me and I must restart the program. I do so and I need to enter the key again and I must restart and this happens over and over.
I cannot use the program because of this.
What must I do please to sort out this problem?
I am fairly sure I had the exact same problem when I very first registered.
dog-man
Re: Licence problem
#2You must enter CD (~35 chars) or shareit# in key field.
Please mail me directly is still problem.
Re: Licence problem
#3It won't let me paste the correct CD key over the one that is there, but I will try again and if it fails again I will contact you.
dog-man
dog-man
Re: Licence problem
#4Now sorted.
I had forgotten that I had replaced my faulty TBS 6925 card with my Skystar 2 Express HD card so it had a different hardware4 id.
I have now registered a second id and all is well.
Thank You.......
Thank You.......
