Installation does not work without errors on Vista64:
Error opeing file for writing:
C:\Program Files\ProgDVB\Modules\BDA.Device
I have then to manually delete (or move away) that file and click on "retry" ...
Same problem with
C:\Program Files\ProgDVB\ProgLauncher.exe
btw: I had the same problem with last update!
Re: Installation reports errors when trying to open files ..
#2Please manual close ProgLauncher before installation. May be some problems with rights/UAC.
#3Oops ... OK, but would be nice to get a warning or the program itself would quit (or the installer would kill them) ...
#4Installer must automatic to close ProgLaucher.
#5Can you please fix that! When updating from 7.00 to 7.02.0 the problem is still there – EVEN IF MANUALLY quitting ProgLauncher before! And what is really sucking: if update is once started (and you did not quit ProgLauncher before), you even can't kill ProgLauncher-process by the TaskManager. And also sucking: you cannot give free BDA.Device with Unlocker as there is no handle blocking it. The only solution is to manually move that file (BDA.Device) away manually and retry! btw: that was on XP!
#6Do you use ProgLauncher from same folder like current installation process?
#7I don't know ... I never used it. It got installed with the program itself, and I did not touch it ... I then right-clicked onto the tray-icon and deselected "start with windows", so it is not appearing there anymore. But that's only since that update (with problems). I'll see what will happen with next update ...
#8OK, solution is simple: if problem occurs, go to system tray and exit manually ProgLauncher, then click onto "retry" (and continue installation) ...
