    • Unanswered topics
    • Active topics
Media Server with DLNA?
1 post
Thex
Thex
Mon Dec 30, 2013 3:16 pm
#1 by Thex
Hi.
I think that would be great addition as it's already working with some third party UPnP progs.
Thus the channel switch at the Client and server is going simultaneously
can next client switch only to channels from same TP?
  • Mon Dec 30, 2013 3:34 pm
1 post
Return to “Modules”
Re: ProgTV 3.8.3 - Trail Peri…
Do you have license? In any case - try install previous version of ProgTV. I'll test it again tomorrow
Prog, Sun Sep 07, 2025 3:15 am
ProgTV 3.8.3 - Trail Period E…
On my Windows 11 machines, I am now getting this message in a pop-up box - WinLicense Your trial period has expired
MG317, Sat Sep 06, 2025 4:51 pm
Re: IPTV channel list issues
1. I changed the leading character to * and it sorts properly now. It seems you are removing leading . characters from t
noremorse57, Sat Sep 06, 2025 2:08 pm
Re: first response feedback
Thanks for feedback. It is more convenient to respond to text as in a video. 1. I am not can repeat first problem with
Prog, Fri Sep 05, 2025 4:21 pm
  • It is currently Mon Sep 08, 2025 10:53 am
