Prog DVB does not recogniza Tevii S420 card
magdym01
magdym01
Wed Jan 08, 2014 8:43 pm
#1 by magdym01
dear all,
I have a problem that the Prog DVB cant recognize the satellite card (TeVii S420) when I upgrade my PC to win 8
kindly advice
  • Wed Jan 08, 2014 8:53 pm
Re: Prog DVB does not recogniza Tevii S420 card
Do you have this device in device manager? Try ProgDVB x32 at first.
  • Thu Jan 09, 2014 6:35 am
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 11:46 am
