Fix Channels please
gote
gote
Fri Jun 27, 2014 11:08 pm
Fix Channels please
#1 by gote
I have a question for you on the previous version folder bulgaria 2 channels working
and now not working says resource not found 404 can you fix
  • Fri Jun 27, 2014 11:27 pm
Re: Fix Channels please
You can try install old version and check again. Usually 404 mean problem with links :(
  • Sat Jun 28, 2014 5:27 am
jalendran
jalendran
Fri Jan 27, 2012 1:09 pm
#3 by jalendran
If I install old versions list of channels was there. But when opening progdvb, automatically updates channels and old channels were deleted and new channels were updating. how to stop updating internet tv
Thank you
  • Sun Oct 09, 2022 2:46 am
#4 by Prog
What list? What source you select in ProgDVB->TV sources?
  • Sun Oct 09, 2022 4:17 pm
Return to “Internet TV and Radio”
Из России и Нидерладов файл доступен. Пользователи пока не жаловались.
Prog, Thu Jun 04, 2026 5:44 pm
Качается... Какие то региональные ограничения? Если и есть, то с вашей стороны. Попробуйте через tor-browser!
Mostwanted, Thu Jun 04, 2026 12:24 pm
Prog, Thu Jun 04, 2026 12:13 pm
https://files4.progdvb.com/progdvb/ProgDVB7.71.5x64.exe
Mostwanted, Thu Jun 04, 2026 10:29 am
  • It is currently Tue Jun 09, 2026 11:46 pm
