    • Unanswered topics
    • Active topics
what difference between IPTV and DVB over IP ?
redge
redge
Sat Apr 26, 2014 10:38 am
#1 by redge
i use only IPTV,
progdvbnet without tuner trough Internet service provider
DVB over IP ?
better or opposite or complementary ?
advantage ?
disadvantage ?
thank you for help
  • Wed Jul 02, 2014 11:03 pm
Re: what difference between IPTV and DVB over IP ?
DVB over IP is some settings preset of IPTV. You can use IPTV Client for any m3u lists.
  • Thu Jul 03, 2014 5:56 am
redge
redge
#3 by redge
thank you for the hint
  • Thu Jul 03, 2014 11:18 pm
waleed
waleed
Fri Oct 10, 2014 7:16 am
#4 by waleed
Thanks Prog :D
I already purchased ProgDVB Prof. and activate with key
Other question: Are there any Spanish translation for 7.xx.xx versions ?
Regards
Get fast success in free braindumps and CITRIX exam questions .
  • Fri Oct 10, 2014 7:23 am
User avatar
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of c
Boofie2010, Sat Dec 13, 2025 2:32 pm
I am not can open this link. server return 884 error. You can try open in web browser, save file and send me. And of cou
Prog, Fri Dec 12, 2025 11:11 am
Playlist sent by pm
Boofie2010, Thu Dec 11, 2025 9:46 pm
  • It is currently Sun Dec 14, 2025 1:43 am
