    • Unanswered topics
    • Active topics
How To Activate ProgDVB Pro on 2nd Computer ?
Rubber Fánny
Rubber Fánny
Wed Sep 18, 2013 7:33 am
#1 by Rubber Fánny
Hi,
I have a licence for ProgDVB Pro v6 and I want to install and activate on a 2nd computer. How do I do this ?
Thx
  • Sun Aug 10, 2014 5:46 pm
Re: How To Activate ProgDVB Pro on 2nd Computer ?
You must enter same data in activation dialog on second PC.
  • Mon Aug 11, 2014 6:20 am
Rubber Fánny
Rubber Fánny
#3 by Rubber Fánny
Prog wrote:You must enter same data in activation dialog on second PC.
I try this with the "Register" option and it fail, it says details already registered ??
Do I use the "Register" option or do I use the "Update" option to activate on my 2nd PC ?
The activation server page does not say what option to use to activate on a 2nd PC ?
Thx for help
  • Wed Aug 13, 2014 10:11 am
#4 by Prog
Send me screen with error and dialog on email.
  • Wed Aug 13, 2014 1:44 pm
Rubber Fánny
Rubber Fánny
#5 by Rubber Fánny
Prog wrote:Send me screen with error and dialog on email.
What email to send screen capture to ?
  • Wed Aug 13, 2014 2:38 pm
Thex
Thex
Mon Dec 30, 2013 3:16 pm
#6 by Thex
on the left menu Support :arrow:
  • Wed Aug 13, 2014 6:12 pm
Re: The sound of voices in mo…
Hello. Do you use libvlc mode? You can try ProgDVB Engine also. Options->Playback->VOD = ProgDVB Engine. + You can try s
Prog, Tue Aug 05, 2025 5:27 pm
The sound of voices in movies.
Hello, I bought the ProgTV version and I have a problem, when I am in my movies section and I play one, the sound of the
ThePoGoBoY, Tue Aug 05, 2025 12:36 pm
Re: проблемма со звуком
А что за провайдер такой? Более чем странный подход. Скорее 25 лет как ТВ занимаюсь, в первый раз вижу. У меня не о
kostan, Mon Aug 04, 2025 3:13 pm
Prog, Mon Aug 04, 2025 12:39 pm
  • It is currently Tue Aug 05, 2025 6:18 pm
