Progdvb channel scanner problem about
arslanlar06
arslanlar06
Wed Nov 19, 2014 1:33 pm
#1 by arslanlar06
Hi,
I have hauppauge HVR-4000 hybrid TV CARD that I using Progdvb trial version 7.07.5 on Windows 8.1 x64 while channel searching on the programs, that it could find vertical channels well, but it couldn't any find horizantal channels, can you help me about this problems,
Best regards,
  • Fri Nov 21, 2014 12:29 pm
Re: Progdvb channel scanner problem about
Any diseq devices? Or cable too long?
  • Sat Nov 22, 2014 8:09 pm
FTA_Boy
FTA_Boy
Sun Jul 31, 2011 8:31 am
Contact:
  • Yahoo Messenger
#3 by FTA_Boy
i think its a LNB problem...
  • Sun Nov 23, 2014 4:11 pm
Return to “Hardware”
Re: Technisat Skystar USB HD
  • It is currently Fri Jun 19, 2026 9:48 am
