    • Unanswered topics
    • Active topics
HD channels in U.K. dont work with nooelec dongle
ganjor86
ganjor86
Fri Jan 23, 2015 11:50 am
#1 by ganjor86
Hello. I buy a dongle like this http://www.ebay.co.uk/itm/Hot-Sale-RTL- ... 43d67531c6 all mux work but not dtg6 (256QAM 32KE 2/340.2Mb/s DVB-T2 MPEG4) is it posible to watch this mux with my dongle ? This is a link to my transmitter http://www.ukfree.tv/transmitters/tv/Waltham
  • Fri Jan 23, 2015 12:03 pm
Re: HD channels in U.K. dont work with nooelec dongle
Do you try manual scanner?
  • Sat Jan 24, 2015 6:57 am
ganjor86
ganjor86
#3 by ganjor86
Just scan the freq with hd mux ?
  • Sat Jan 24, 2015 12:53 pm
#4 by Prog
Yes. Manual select all params.
  • Sat Jan 24, 2015 2:16 pm
ganjor86
ganjor86
#5 by ganjor86
ProgDVB dont see mux on 770MHz the rest hawe 100% of quality.
  • Sat Jan 24, 2015 3:23 pm
#6 by Prog
Is it possible scan channels in this dialog?
  • Sun Jan 25, 2015 3:19 pm
ganjor86
ganjor86
#7 by ganjor86
Witch dialog ?
  • Sun Jan 25, 2015 8:01 pm
#8 by Prog
Channel list->Manual scanner.
  • Mon Jan 26, 2015 9:15 am
ganjor86
ganjor86
#9 by ganjor86
ProgDVB dont see level and quality of signal ( just 0%): psb3, lng, com7. Rest of mux work normal without problems.
  • Mon Jan 26, 2015 8:07 pm
#10 by Prog
Do you have signal in software from DVD?
  • Fri Jan 30, 2015 1:19 pm
ganjor86
ganjor86
#11 by ganjor86
How to check this ?
  • Fri Jan 30, 2015 8:11 pm
#12 by Prog
Do you have some software with device? Or on official site?
  • Sat Jan 31, 2015 6:11 am
Return to “Hardware”
  • It is currently Sun Jun 15, 2025 10:41 am
