    • Unanswered topics
    • Active topics
ProgTV1.07 android problem when stream from PC DVBS card to
star
star
Sat Jul 23, 2011 11:05 pm
#1 by star
ProgTV1.07 android problem when stream from PC DVBS card to mobile !
only channel work is HD only and no sound !
I have a dish and PC to Mobile not work good.
  • Sat Jan 31, 2015 1:47 am
Re: ProgTV1.07 android problem when stream from PC DVBS card
ProgTV for Android use android codecs. But most Android devices not have codec for mpeg2 (not HD channels). Same with AC3. What audio format you use?
ps: Not bad codec collection on Android boxs for video playback. Like minix or other cheaper devices.
  • Sat Jan 31, 2015 6:10 am
star
star
#3 by star
what the best codec for sony xperia z1 ?
  • Sat Jan 31, 2015 7:04 pm
#4 by Prog
I am not know way for installation codec on android. Need transcoding on server site (not supported in current version) or other way of playback on client. Or special android device for playback :(
  • Sat Jan 31, 2015 7:08 pm
#5 by Prog
Or you can use m3u from Prog Media client in other android player.
  • Sat Jan 31, 2015 7:10 pm
star
star
#6 by star
Prog wrote:Or you can use m3u from Prog Media client in other android player.
what is the best player ?
  • Mon Feb 02, 2015 9:57 pm
#7 by Prog
You can try 2-3 IPTV players for experiment.
  • Tue Feb 03, 2015 4:39 pm
star
star
#8 by star
Prog wrote:You can try 2-3 IPTV players for experiment.
I try
IP-TV with BSPlayer FREE is work good but 4K Channel in hotbird ( HOT BIRD 4k1 )
10930 H 30000 not work good is low FPS
and IPTV in Progdvb not work with diseqc good load only one sat not other sat
IP-TV
https://play.google.com/store/apps/deta ... smart.iptv
BSPlayer FREE
https://play.google.com/store/apps/deta ... droid.free
  • Sat Feb 14, 2015 8:18 pm
#9 by Prog
Afaik 4K not high bitrate for WiFi and android.
About diseq. Do you try collect channels from different lists in one?
  • Sun Feb 15, 2015 6:53 am
star
star
#10 by star
Prog wrote:Afaik 4K not high bitrate for WiFi and android.
wifi in sony xperia z1 = 72 Mb speed and mobile is support 4K videos I try sample 4K work very good
the router is tp-link TD-W8970 is support up to 450 Mb wifi speed
-I not try collect channels from different lists in one!
  • Sun Feb 15, 2015 7:23 pm
#11 by Prog
If low FPS then low CPU or WiFi speed (important real speed)
  • Mon Feb 16, 2015 10:17 am
star
star
#12 by star
Prog wrote:If low FPS then low CPU or WiFi speed (important real speed)
the CPU in PC intel i7 3770K @ 4.3 Ghz
in mobile sony Snapdragon 800 2.1 Ghz Quad Core
but the speed on Wifi in mobile 72 Mb
in computer used Lan Speed is 1 GB speed and router is 450 MB Speed
  • Mon Feb 16, 2015 9:00 pm
#13 by Prog
You must check real speed. Try transfer file.
  • Tue Feb 17, 2015 4:52 am
star
star
#14 by star
Prog wrote:You must check real speed. Try transfer file.
the transfer speed no problem I transfer 200 mb = 30 seconds
  • Fri Feb 20, 2015 11:03 pm
Return to “ProgTV Android”
Re: Lib VLC Engine Pop Up
In prerelease fix of Engine mode. But this is not last update...
Prog, Tue Aug 05, 2025 9:22 pm
Re: The sound of voices in mo…
Hello. Do you use libvlc mode? You can try ProgDVB Engine also. Options->Playback->VOD = ProgDVB Engine. + You can try s
Prog, Tue Aug 05, 2025 5:27 pm
The sound of voices in movies.
Hello, I bought the ProgTV version and I have a problem, when I am in my movies section and I play one, the sound of the
ThePoGoBoY, Tue Aug 05, 2025 12:36 pm
Re: проблемма со звуком
А что за провайдер такой? Более чем странный подход. Скорее 25 лет как ТВ занимаюсь, в первый раз вижу. У меня не о
kostan, Mon Aug 04, 2025 3:13 pm
  • It is currently Tue Aug 05, 2025 9:46 pm
