    • Unanswered topics
    • Active topics
"Reset all settings" after crash: please change single click
1 post
Kakadu
Kakadu
Fri Oct 01, 2010 10:26 pm
#1 by Kakadu
"Reset all settings" after crash is a nice thing – but can you please change the settings so that "Single Click Channel Select" is kept as it was before crash and not resetted? Btw.: Key Binding is also not resetted; that setting (single click) should also be kept as it was before the crash and not be reset ...
Thank you.
Btw: I prefer having Wheel-Up/Down for CH+/CH- ... I put Vol+/- to Shift-Wheel-Up/Down and Zoom+/- to Ctrl-Whell-Up/Down
  • Wed Apr 15, 2015 11:37 am
1 post
  • It is currently Wed Jun 18, 2025 4:35 am
