    • Unanswered topics
    • Active topics
GeniatechHD START DVB-S USB
Moayidd
Moayidd
Sat Apr 25, 2015 3:48 pm
#1 by Moayidd
HI,
I, entirely new to all this. What device do I choose from the Device list for GeniaTech HD STar DVB-S USB ?
Im running win7 x64, Should I use the 64bit drivers or the 32bit drivers as is suggested in some posts here ?
Regards
  • Sat Apr 25, 2015 3:54 pm
Re: GeniatechHD START DVB-S USB
Look {BDA}........ device. You can try x32 version also (more typical for driver)
  • Sun Apr 26, 2015 6:33 am
Return to “Hardware”
  • It is currently Sat Jun 14, 2025 12:05 am
