    • Unanswered topics
    • Active topics
DNS troubles with domain progdvb.com
evarost
evarost
Fri May 23, 2014 6:56 am
#1 by evarost
Hi,
A note to administrator:
The dns name "files.progdvb.com" isn't resolved by public DNS servers, like 8.8.8.8/8.8.4.4
It's ok for "www.progdvb.com" but not for the first.
I hope troubles will be fixed soon!
  • Wed Jun 17, 2015 1:04 pm
Re: DNS troubles with domain progdvb.com
New host and new IP 2-4 weeks ago. May be some old IP in dns cache.
  • Wed Jun 17, 2015 2:49 pm
evarost
evarost
#3 by evarost
Prog wrote:New host and new IP 2-4 weeks ago. May be some old IP in dns cache.
Ummm... the problem is that Google public DNS servers don't resolve your domain!
Try it: change your DNS server to 8.8.8.8 and/or 8.8.4.4 and surf over your servers.
  • Wed Jun 17, 2015 4:48 pm
#4 by Prog
Do you try clean dns cache?
  • Wed Jun 17, 2015 5:16 pm
#5 by Prog
Try now again.
  • Thu Jun 18, 2015 6:53 am
evarost
evarost
#6 by evarost
Hi,
Here my result (clean DNS cache on a Linux machine with DNS server 8.8.8.8 ):
root@localhost:~# ping http://www.progdvb.com
PING http://www.progdvb.com (85.17.197.78): 56 data bytes
root@localhost:~# ping forum2.progdvb.com
ping: bad address 'forum2.progdvb.com'
root@localhost:~# ping files.progdvb.com
ping: bad address 'files.progdvb.com'
  • Thu Jun 18, 2015 9:29 am
Re: Lib VLC Engine Pop Up
In prerelease fix of Engine mode. But this is not last update...
Prog, Tue Aug 05, 2025 9:22 pm
Re: The sound of voices in mo…
Hello. Do you use libvlc mode? You can try ProgDVB Engine also. Options->Playback->VOD = ProgDVB Engine. + You can try s
Prog, Tue Aug 05, 2025 5:27 pm
The sound of voices in movies.
Hello, I bought the ProgTV version and I have a problem, when I am in my movies section and I play one, the sound of the
ThePoGoBoY, Tue Aug 05, 2025 12:36 pm
Re: проблемма со звуком
А что за провайдер такой? Более чем странный подход. Скорее 25 лет как ТВ занимаюсь, в первый раз вижу. У меня не о
kostan, Mon Aug 04, 2025 3:13 pm
  • It is currently Wed Aug 06, 2025 5:45 am
