Re: progDvb 7.11 Crash every time when plugin searches a key
meh! :-/ if found the problem is related to "Prog" mode (demultiplexor) in settings > options > main > demultiplexor.
no problem with other modes (Elecard , Microsoft , CyberLink , ArcSoft)
@mrk182: can you try change demultiplexor to something else (Microsoft...) and let us know the result from you too ?
Prog wrote:Can you add "log2=1" to ProgDVB.ini in [Debug] section and make logs of crash with Prog demux?
i did what you requested Mr Prog!. attached the logs folder with "log2=1" enabled in progdvb.ini setting files with prog demux in use.
Logs.zip
(37.18 KiB) Downloaded 277 times
ps: the internet tv channel was buffering (picture was freezed) and i changed the channel.
also a screen shot when ProgDVB is not responding ...
@mrk182: good ;) now can you please attache a log as Prog said (log2=1)?
Prog wrote:Can you send me log with log2=1 from current prerelease?
as you requested : here is logs2=1 with progdvb v7.11.02d (latest prelekease). i was watch IPTV channel "private" the picture stoped due to buffering and i changed to another iptv channel "club1", the whole program stopped responding.
i also put the ProgDVB.ini setting file for you in zip.
Logs-v7.11.02d-iptv.zip
(42.42 KiB) Downloaded 239 times
here is another log2=1 of this crash with dvbs channels and cccam plugin. i described more at picture:
http://up.iranhack.org/uploads/d7hqhqb5bvtipstky7q.jpg
and time shift not work with this prerelease -_-
http://up.iranhack.org/uploads/pe8fyzd1igh5lvs4a9m.jpg
Logs-v7.11.02d-dvbs.zip
(268.94 KiB) Downloaded 266 times
