    • Unanswered topics
    • Active topics
Both 32 and 64bit doesn't recognize my card in Win10 64bit !
lasvegaswings
lasvegaswings
Tue Nov 17, 2015 5:17 pm
#1 by lasvegaswings
My tuner is Skystar S2.
OS is Win10 64bit.
I use WDM drivers.
I tried both 32 and 64bit versions of ProgDVB but it couldn't recognize my tuner.
It recognize with the BDA drivers but BDA drivers don't operate good with Win10.
It slows down the PC and crashes much.
Even 1 transponder search takes at least 1 minute to be done.
What should i do?
  • Tue Nov 17, 2015 5:30 pm
Re: Both 32 and 64bit doesn't recognize my card in Win10 64b
You must install software from CD for WDM working.
  • Tue Nov 17, 2015 5:37 pm
lasvegaswings
lasvegaswings
#3 by lasvegaswings
Prog wrote:You must install software from CD for WDM working.
WDM drivers on CD doesn't work too, i tried.
ProgDVB must to be updated for Skystar tuners.
  • Tue Nov 17, 2015 9:27 pm
#4 by Prog
ProgDVB working over official SDK (Sky2PCAVSrc.ax). install last driver and last software (for registration Sky2PCAVSrc.ax in OS)
  • Wed Nov 18, 2015 4:08 am
Return to “Hardware”
Re: ProgTV 3.8.3 - Trail Peri…
Do you have license? In any case - try install previous version of ProgTV. I'll test it again tomorrow
Prog, Sun Sep 07, 2025 3:15 am
ProgTV 3.8.3 - Trail Period E…
On my Windows 11 machines, I am now getting this message in a pop-up box - WinLicense Your trial period has expired
MG317, Sat Sep 06, 2025 4:51 pm
Re: IPTV channel list issues
1. I changed the leading character to * and it sorts properly now. It seems you are removing leading . characters from t
noremorse57, Sat Sep 06, 2025 2:08 pm
Re: first response feedback
Thanks for feedback. It is more convenient to respond to text as in a video. 1. I am not can repeat first problem with
Prog, Fri Sep 05, 2025 4:21 pm
  • It is currently Mon Sep 08, 2025 10:53 am
