RTSP freebox with ProgTV for Android
Hello,
I'm trying to use ProgTV for Android with the m3u file from my internet provider.
In the m3u file, i have this address for a channel :
rtsp://mafreebox.freebox.fr/fbxtv_pub/stream?namespace=1&service=201
But I have always an error message "Server error" with ProgTV.
Could you tell me if ProgTV for Android is compatible with my provider and rtsp address? If yes, what do I need to do?
Thank you.
Re: RTSP freebox with ProgTV for Android
I did several tests with 2 different box TV with ProgTV Android v2.07.8 (11.12)
With and without the engine and with 2 different video streams.
First Box
MXIII-G / Android 5.1
CPU : Amlogic S812 Quad Core up to 2.0GHz (Cortex-A9)
GPU : Octa core ARM Mali-450 GPU up to 600MHz
RAM : DDR3 2GB
Results :
With Engine
RTSP from my internet provider —> OK
(example : rtsp://212.27.38.253/fbxtv_pub/stream?namespace=1&service=201&flavour=hd)
HTTP —> App Crash
(example : http://xxxxx.com:88/live/xxxxx/xxxxx/181.ts)
Without Engine
HTTP —>OK
But the quality is not as good as with Engine.
Logs : Logs_xiii_with_Egine.zip and Logs_xiii_without_Egine.zip
Second Box
Freebox Mini 4K / Android TV
CPU : A15 Dual Core 1,5 Ghz
GPU : ??
RAM : DDR3 2GB
Results :
With Engine
RTSP from my internet provider —> KO (Server error)
HTTP —>OK
Without Engine
RTSP from my internet provider —> OK, but poor video quality.
HTTP —>OK
I'm not able to export log with this box. I have an error message about folder permissions .
(40.26 KiB) Downloaded 348 times
(19.19 KiB) Downloaded 356 times
Without "engine" playback total depended from device. I am not have any tools for change that. Crash in Engine in http not typical. But bigest problem is AC3 format of audio. very commercial format and I am not have license. May be this channel have other audio stream?
ps: try enable FFD for h264 channel. Still crash?
